Up to 20% off select tools
The Enclave has seating for seven passengers, with an optional second row bench seat instead of the standard two captain chairs which increases the seating to eight. It comes standard with front-wheel drive with an option of all-wheel drive.
Reduced engine power problems
Why is it not running right , I’ve replaced throttle body and gas pedal
Add a comment
1 Answer
Most Helpful Answer
Hi @cliffordlachman
Get the vehicle's OBDII port scanned with an appropriate scantool to see if any DTC codes have been logged.
If there are codes shown, the code will tell you what the problem is.
If you're in the USA major auto parts stores e.g. AutoZone, PepBoys, O'Reilleys, will do this for free apparently.
Score 2
Add a comment
Add your answer
Clifford Lachman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 170
