Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
No display or power led
Hey, I’m kinda stuck on a PSP-1000. Battery and charger are good (checked with a basic voltage tester), but the thing just won’t turn on. No power LED, no screen, no sound.
I’ve already tried:
  • Different batteries
  • A new charging port
  • A new button board
  • Reseating the grey ribbon cable
Power is getting through (even to the LED board), but the LEDs never light up. Hold switch moves fine. Same result every time.
Before I drop like $50 on a replacement motherboard, does anyone know any common PSP-1000 issues that cause this? Bad ribbon cable? Blown component? Something dumb I’m overlooking?
Any help would be appreciated
Add a comment
1 Answer
Most Helpful Answer
Hi!
It could be the power board or the ribbon cable that connects from it to the motherboard.
I would replace those first and test.
If both didn’t worked, then you do need to replace the motherboard…
Since it does charge, I will try that first.
If you need guides, please let me know!
Score 1
Add a comment
Add your answer
Alan Olvera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 104
