iPod nano 4th damaged pad
hi, I damaged the ipod nano 4th pad, the one in the middle, anyone know where do i have to connect it to using a copper wire? I will appreciate it. Thanks
It looks like the middle solder pad is missing where the battery ribbon cable connects to the logic board. This is the battery thermal sensor and needs to be connected.
You'll need to recreate the solder pad with copper board repair foil and then locate the severed line to splice it in as well. You'll need something like this Single-Sided Conductive Tape Copper Foil Tape. You might find a patch kit will give you what you need with the other materials to patch things.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 137
