Camera display not showing the correct image
LCD DISPLAY NOT WORKING
Does the image look OK when you plug in an external display? There is a port inside the memory card slot. If it is clean then the issue is within the display it's self which will require a new one
If the photo file is fine when opened on a PC, the problem is clearly with your LCD. Replacement is needed. You can find spare parts online. Here's a video link for a Canon 1100D repair: https://www.youtube.com/watch?v=DEjK37jv... It's probably not much different from the EOS 5D.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 72
