Why is my mouse frequently disconnecting
My mouse started disconnecting and when I got powered usb hub it works fine but for 2-3 minutes it freeze for a second
Score
0
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 32
All Time: 57
Several possibilities, driver issues see if you can find the driver or app (Logitech has a unifying app that might help) and see if that helps especially if you can test the port.
Also if your using windows search for event view and under windows and then system you might see some events that corispond with the times it disconnected and then you can copy paste the event into copilot or chatgpt and it can tell you what it means.. this helps a lot at work.
Otherwise maybe the mouse is faulty.
by Edge Ldine (Lovagrend)
