The Razer Blade 12" (2022) RZ09-0421x is gaming laptop released in 2022.
What component is this and what are its specs?
I got the laptop a while back for 40 bucks off a friend and it won’t draw any power. I opened it and It looks like a capacitor shorted on the heat sink with the power pins. Need some help identifying it.
I have removed the old one and it is the one that went directly below the charging port in the photo
1 Comment:
@johannwint93364 try a more focused picture with a bit more light. Also, what model number is that motherboard?
by
Add a comment
1 Answer
I believe you did all of this.
You need a voltmeter (or multimeter), first check the power supply plug, if it shows 0 the problem is with the power supply, if there is normal voltage, you need to check the socket on the computer, if it is also normal you need to check the output/input voltage of the battery.
1 Comment:
I ordered a new power supply which works but still won’t boot. The battery is basically too broken to be used but it ran without it for months just off a power cable
by
Add a comment
Add your answer
Johann Winter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 114
