Repair guides, disassembly, and troubleshooting information for the 10th-generation Apple iPad, available in Wi-Fi and cellular versions with 64 or 256 GB of storage. Released in October 2022. Identified by model numbers A2696, A2757, A2777, or A3162.
Is there a LCD and Digitizer replacement guide?
i'm trying to find a lcd and digitizer combo and installation guide.
Add a comment
Most Helpful Answer
No luck locating a written guide, but this YouTube video seems to be reasonably well done and has all the information you should need to remove and replace the LCD and/or digitizer.
iPad 10 Screen Replacement Guide – Tools, Tips, and Color-Coded Screw Locations! - YouTube
Score 1
Add a comment
Hi, @apollo5727 I gotchu.
LCD, Digitizer
We could not find a guide, but you can try doing this:
1: Use the iOpener and heat the side of the iPad, then insert an opening pick 3mm inside. Repeat this for the other sides, trying to not interfere with cables.
2: Lift the iPad digitizer assembly, then you will reach the LCD. Unscrew the screws using a 00 Phillips driver. Then lift the LCD.
Please, if you can, give us a guide about this repair. How to start a new guide
Replace a scratched or cracked glass digitizer touch screen for an iPad 10 or iPad 11. This part is only the front glass. The LCD is not included. Image
Product
iPad 10/11 Screen Digitizer
$59.99
Add a comment
Add your answer
Apollo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 169
