The Sony DualSense Edge (CFI-ZCP1) wireless controller was released in January 2023. It features replaceable joystick modules and other upgrades from the DualSense.
Fn button stuck in pressed state
Pad just stuck in profile select mode due to always pressed right Fn button, I swapped the modules and even bought new ones, but it didn't help.
also i have this: 0300e0274c050000f20d000000016800,*,a:b0,b:b1,back:b4,dpdown:h0.4,dpleft:h0.8,dpright:h0.2,dpup:h0.1,guide:b5,leftshoulder:b9,leftstick:b7,lefttrigger:a4,leftx:a0,lefty:a1,rightshoulder:b10,rightstick:b8,righttrigger:a5,rightx:a2,righty:a3,start:b6,x:b2,y:b3,touchpad:b11,misc1:b12,paddle1:b16,paddle2:b15,paddle3:b14,paddle4:b13,crc:27e0,platform:macOS,
So the main question is how to understand what exactly the problem is next, and what to change, since this is definitely not a problem with the stick module.
Add a comment
1 Answer
Most Helpful Answer
Hi!
Then it's most likely something on the board.
Try to clean the connector and inspect if there are any bent pins.
If it's bent, try to fix it.
In the worst case, you need to replace the port or replace the board.
Guide: DualSense Edge Motherboard Replacement
If possible, can you sent us some pictures regarding the joystick port?
Thanks!
Score 1
2 Comments:
Actually, it sat for almost a year after I bought it. I simply forgot about it. It only showed up after 4-5 days of use, and I didn't have time to replace it. I cleaned the connectors with rubbing alcohol, but everything was still the same. I'll post a photo later, I'm not at home right now. I also thought it might be the motherboard, since there's nothing else there that could cause this. And thanks for the reply! I'll send photo as soon as I get home)
by
Thank you! That is most likely it yes. Nothing else should be able to cause this, so far I'm aware of.
Please let us know when you have an update :). Thanks!
by
Add a comment
Add your answer
Granchik will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 97
All Time: 457
