The Canon PIXMA G3010 is an all-in-one wireless MegaTank printer that was released in early 2018. It supports printing, scanning, and copying, with built-in Wi-Fi and Direct Wireless connection for easy mobile printing
The printer is failing to print
whenever I need a printout it always says eror with with the printer
Update (04/14/26)
It is failing to print
Score 1
Add a comment
Hi, @agastyaabh96343 I gotchu.
Try unplugging it, leaving it for 1 minute then plugging it in again
Add a comment
  • Check Power Supply ЁЯФМ
    Make sure the printer is turned ON and properly connected to the power source.
  • Check Printer Connection ЁЯФЧ
    Ensure the printer is correctly connected to the computer via USB cable or Wi-Fi network.
  • Check Paper Availability ЁЯУД
    Confirm that paper is loaded properly in the paper tray and not jammed.
  • Check Ink or Toner Levels ЁЯЦЛя╕П
    Replace or refill the ink/toner cartridge if it is empty or low.
  • Check for Paper Jam ЁЯЪлЁЯУД
    Open the printer and remove any jammed paper carefully.
  • Restart Printer and Computer ЁЯФД
    Turn off both devices, wait a few seconds, then turn them back on.
  • Set Printer as Default тЪЩя╕П
    Make sure the correct printer is selected as the default printer on the computer.
  • Update or Reinstall Printer Driver ЁЯТ╗
    Install the correct printer driver if the printer is not responding.
1 Comment:
@suwaidionline while AI can be a helpful starting point, we ask that users are transparent when utilizing AI-generated answers. If you post an AI response, you are responsible for its content and must explicitly state that the information was generated by AI.
It is vital that the person sharing the AI response validate all suggestions for 100% accuracy and safety. Incorrect or unverified advice can lead to property damage or personal injury, and the responsibility for ensuring the information is sound rests entirely with the user posting the response.
by
Add a comment
Sounds like a general driver/connection issue, try a printer and PC reboot, clear print queue and reinstall the driver.
1 Comment:
Kaise saaf kr sakte hain
by
Add a comment
рдореЗрд░рд╛ рдкреНрд░реАрдВрдЯрд░ рдХреБрдЫ рднреА рд╕рд╛рдл рдирд╣реАрдВ рдЫрд╛рдк рд░рд╣рд╛ рд╣реИред
Translation Hindi - English
My printer is not printing clearly.
2 Comments:
@ammikatige95711 your printer is a Canon PIXMA G3010? what have you already checked and what have you already tried?
@ammikatige95711 рдХреНрдпрд╛ рдЖрдкрдХрд╛ рдкреНрд░рд┐рдВрдЯрд░ Canon PIXMA G3010 рд╣реИ? рдЖрдкрдиреЗ рдкрд╣рд▓реЗ рд╕реЗ рдХреНрдпрд╛-рдХреНрдпрд╛ рдЬрд╛рдВрдЪрд╛ рд╣реИ рдФрд░ рдЖрдкрдиреЗ рдкрд╣рд▓реЗ рд╕реЗ рдХреНрдпрд╛-рдХреНрдпрд╛ рдЖрдЬрд╝рдорд╛рдпрд╛ рд╣реИ?
by
Print nhi kr rha hai na he photostate kr rha hai
by
Add a comment
Well checkout the following guide: https://www.systweak.com/blogs/fix-print...
Add a comment
Add your answer
Agastya Abhishek Lone will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 109
All Time: 319
