Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
Are the traces broken?
Hi, so my Dualshock 3 my sticks started drifting so I replaced them and that didn't work. So I noticed that there are pads to the main board so cleaned them and I also notice a small foam piece under the pads I've researched that it degrades over time and loosens the adhesive could that be the cause for the drift?
Add a comment
1 Answer
Most Helpful Answer
Hi!
You can find some more info here: https://youtu.be/kS1uVBIhBDw?is=jXzEadwc...
Trace repairing isn’t easy. You need soldering experience and the right tools to get this done.
You can use medium size wires. Not too small and not too big.
Please let us know how it goes!
Score 1
2 Comments:
Whats considered medium size? I have a 30 awg laminated wire
by
That should do. 28 awh or 30awg should do the job!
by
Add a comment
Add your answer
Christopher D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 96
