Also known as a multitester, or a VOM (Volt-Ohm meter), a multimeter is an electronic measuring instrument used to measure voltage, current, and resistance. Includes handheld and tabletop testing devices.
Where can I find replacement leads?
While I was looking at the viability of different "cheap meter" tiers for a guide, I took a look at a few I had on hand (not many) in borderline price brackets, but one of my test meters (Kobalt DMP-32) the leads broke after a few years of use with it. I tested a set from my Fluke meter and it was fine, so I know the leads are bad and the meter itself is fine (except for losing a screw post).
Where can I find the original leads, or at least similar to the FC135 leads? Lowes does not sell them, it appears Lowes does not sell them. Photo here:
Score 1
Add a comment
Chosen Solution
Hi @nick
This supplier has a selection of leads with different plug types that may be of interest. Scroll down to find ones that may suit. Check their datasheet to verify
Score 2
1 Comment:
So I opened it to check the other posts being one broke and that’s never good. All remaining 3 are on the way out so I’ll just borrow some leads from another meter until it falls open.
by
Add a comment
Are the posts that plug into the meter shrouded or exposed? That's been the biggest factor I've run into when looking for replacement leads. Can you add a picture of the other end of the leads?
Score 2
1 Comment:
I know where they are but it uses the same fully shrouded cables my other meters use. However the screw posts are failing and I don’t know if I want to buy leads for a failing meter.
by
Add a comment
Ebay, Amazon, etc etc.
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 133
