How can I remove stuck Y000 screws?
The screws on the back of my Switch (original - the one that can fit in the cradle to display on a TV) are super-tight. One came out, but the next one is so tightly in that when I tried using the iFixit toolkit's Y000 screwdriver, it just stripped the slots on that screw.
I know I can find replacement screws, but how can I get these screws out? (The other two are in there tight, but I haven't fully mangled them yet.)
I should add that I've removed stripped screws before, but never this small and the screws are recessed enough that makes many of the "normal" options for removing them hard to use. (Also, considering the rubber band method - that's a problem since the slots are so tiny that I don't see how the screwdriver blades could do anything with the slots through the thickness of rubber.)
Update (04/06/26)
I used a different screwdriver and that worked.
The iFixit Y000 bit I was trying had a bad angle on the end that didn't really fit well into the screws: Here's a simple (and lopsided!) illustratoin:
The screwdriver tip was at a sharp angle, so the blades really didn't fit into the slot enough to actually do anything. It just wasn't designed well. I found another screwdriver with the same size bit and with a better profile to match the screw slot.
