Announced on September 28, 2023, the Raspberry Pi 5 acts as a revision of the Raspberry 4B's hardware.
Change PCIe plastic clip
I broke one side of the plastic clip which keep in place the FFC cable, is there a way to replace just the clip and not the entire PCIe connector? I was able to push the clip back inside and for now seems like it could stay in place and the nvme hat it's working but better safe than sorry
Aggiorna (04/08/26)
it’s the circled brown clip
2 Comments:
Can you post a nice sharp image so we can see the connectors details.
by
Yes sorry, I updated the question with a photo
by
Add a comment
1 Answer
Well from what I've discovered this as an amphenol connector 62674-161120ALF which sadly is no longer made. Instead this might work F31W-1A7H1-11016
Here's the parts schematic of the original to help guide you. Carefully you should be able to tale the new part apart to salvage the latch
62674 Connector. Otherwise you'll need to desolder the connector to replace it with the alternate connector..
Add a comment
Add your answer
Matteo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 51
All Time: 248
