Up to 20% off select tools
Door latch error code c-d1
Modelnv51k7770dg/aa. Put it on self clean mode. Turned off no power. Replaced the DE47-20037A Samsung Range Oven High Limit Thermostat Thermal Fuse. Powered unit. Now error code for door latch. Tried resetting the latch. Motor feels hot but not cycling. Replacement only option? Could be the control module? Ill consult google and YouTube for more.
Add a comment
1 Answer
Most Helpful Answer
Hi @abe65070
Here's the service manual that may help.
Go to p.41 to see how to troubleshoot a C-d1 for the lock motor and if that is OK, go back to p.40 to check if the main board and oven temp sensor are OK
Score 1
Add a comment
Add your answer
Abe will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 244
