Do not turn on the stop light
Do not turn on the stop light when braking.
Hi @stevenpimto
If none of the brake lights are working, check if the 10A fuse #7 in the instrument panel fuse box is OK.
If the fuse is OK check if the brake light switch on the brake pedal is OK.
Here's a video that may help you to check if both are OK or not.
If the switch is faulty, search online for 2008 Nissan Altima brake light switch to find suppliers that suit you best.
Here's an image of the wiring diagram if there's a wiring problem
(click on image)
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 51
