Up to 20% off select tools
The Samsung Galaxy A71 is an Android smartphone manufactured by Samsung Electronics as part of the Galaxy A series. It was released in January 2020. Versions: SM-A715F/DS, SM-A715F/DSN (Global), SM-A715F/DSM (Russia).
The device cannot be charged
The device cannot be charged by just any charger, not even its original charger; it requires a powerful 30W charger. However, if left charging for an extended period, the battery may discharge and its level may drop.
Add a comment
1 Answer
Most Helpful Answer
Hi!
Well, could be the charge board or the battery.
Does it recognize the charger? If not, you need to replace the charge board.
If yes, you want to replace the battery.
You can follow this guide for some more info: Samsung Galaxy Not Charging
Please let us know how it goes!
Score 1
2 Comments:
I replaced the charging board, the battery, and the flex cable connecting the charging board to the motherboard, but it didn't work. This problem started after I used a low-quality car charger. Thank you for your reply and attention.
by Share
Alright, well you did what you could and replaced everything "charging" related. At this moment I suspect that it's motherboard related...
by Share
Add a comment
Add your answer
Majid Korkli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 123
