The HP 14-db0000 is a Chrome device manufactured by HP, and is apart of the Chromebook 14 line of products.
What can I do to fix this problem?
My laptop will not turn on even after left charging prior, what can I do to fix this problem?
Add a comment
1 Answer
These are some of the methods you can follow-
Hard reset — unplug charger, remove battery (if removable), hold power button 30 seconds, reinsert and try again.
Check the charger — try a different cable/adapter or check if the charging port light comes on.
Force power on — hold power button for 15 seconds straight, some laptops need a long press.
Check for signs of life — listen for fan spin, keyboard lights, or HDD sounds to narrow down the issue.
Connect to external monitor — rules out a screen-only failure.
Remove external devices — unplug all USB drives, mice, and peripherals that could block boot.
Add a comment
Add your answer
Sky Tafolla will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 85
