Repair guides, support, and troubleshooting information for the 15-inch MacBook Air featuring Apple's M3 SoC. Released on March 8th, 2024 and identifiable by model number A3114.
No Display outside of recovery.
Hi, im having a strange issue with an a3114 M3 Macbook Air.
On normal power on it chimes and flashes the power logo for a split second then goes black. When plugged into a dock I get video and it boots. But the Keyboard and mouse also are not working. Only showing the external display in MacOS
When I hold the power button for recovery options I get full display, the keyboard and mouse still don't work but the screen is fine... As soon as I click on options using an external mouse the screen goes blank but again works on external fine.
Im wondering if there is a shared power bus or something that could be shorted. I dont see signs of liquid damage inside the machine but anything is possible...
Anyone got any ideas?
Add a comment
1 Answer
Within the lid hinge is a magnet which interfaces with a Hall sensor within the Uppercase. This sensor notes when the display lid is Down which tells the logic board not to power the display and the keyboard and trackpad as it's not accessable to squeeze out a little more power for the rest of the systems needs.
So... in your case that sensor is not working correctly. Did you have a bang or a spill which is the source of the problem? If not you may need to replace the sensor MacBook Air 15" (2024) AMR Sensor.
Here's the guide to get to it MacBook Air 15" 2024 Screen Replacement follow the guide to get to the Right side (left from the bottom) hinge area reference Step 32.
And here's how to adjust it MacBook Pro 2019 M1 M2 M3 M4 Air Lid Angle Sensor (Sleep Sensor) Calibration without programming
Replace a damaged or malfunctioning AMR Sensor in a 2024 model A3114 MacBook Air 15" laptop. Image
Product
$19.99
Add a comment
Add your answer
Alexander Hlatki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 177
