Up to 20% off select tools
Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
Weird System Power Issue
My 3DS is having a weird issue. When the 3DS's top screen's hinge is at about a 95-degree angle or less, the system works perfectly. However, if I push the screen farther back, the system fully turns off. I should point out that the system is not modded, meaning it isn't an issue after modding.
Add a comment
That is weird. If you are OK with it, can you open it up and check the connections on the motherboard?
Add a comment
Hi!
I’m afraid it’s related to the top screen..
I would replace it and test if that worked.
Guide: Nintendo 3DS XL Upper LCD Display Replacement
Note: it’s pretty difficult to perform this repair, so please check with the guide if you want to proceed or not.
3 Comments:
Just be careful with the old screen, because if that's not the problem, I think you would want to return the new screen to iFixit for a refund.
by Share
Even if I replace the upper screen, why do I need a new speaker assembly?
by Share
What do you mean? I would only replace the topscreen for now.
by Share
Add a comment
Add your answer
Bobus_Oxen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 153
