Released on July 28th, 2017, The New Nintendo 2DS XL is a technologically-improved remodel of the 2DS handheld. It is the ninth and last redesign of the Nintendo DS line, The console is much larger than the original 2DS model and adds all the features of the updated 'New 3DS' line of systems, minus the ability to play games in stereoscopic 3D on the top screen.
How to fix black screen of death?
Whenever I try to power on my 2DS XL, the solid blue LED light comes on, but the screen stays black. I’ve had this issue in the past, but it always seemed to resolve itself when I powered it on and off again multiple times in a row. Now, that’s not working this time. My partner told me maybe it’s a problem with the capacitors?
1 Comment
Does your blue led stay on until you turn it off, and is your console modded with Luma3DS? If so, can you get into the Luma3DS configuration menu by turning on the console while holding the Select button?
by
Add a comment
1 Answer
Most Helpful Answer
Hi!
Could be a lot of things. Which screen is failing? Both of them? If yes, then you might want to check the motherboard.
Also, make sure that the SD card is removed.
Please also try to enter safe mode and see what happens: Using the 3DS's Safe Mode
Can you let us know how that goes? Thanks!
Score 1
Add a comment
Add your answer
Geo B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 36
All Time: 270
