The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Game card slot not working
Ok so I've tried almost everything from putting paper under the game card slot to replacing the card slot.
I tried different games cleaning the games and any software issues that I thought of.
The only two things I can think of is the tiny bit of of blue green corrosion by where the game card connects to the motherboard.
The sd card also is not reading. Please help
Yes I do have pictures sorry if quality is bad
Add a comment
1 Answer
Most Helpful Answer
Hi!
Probably caused by corrosion. You need to clean everything on there with isopropyl alcohol and remove all the corrosion before you proceed.
In the worst case you need to replace the motherboard.
Can you please share some pictures regarding the corrosion?
Adding images to an existing question
Thank you!
Score 1
1 Comment:
Thanks for the pictures! That is definitely corrosion yes. You need to clean it all with isopropyl alcohol and with a toothbrush. Clean it really good and it should come off. Can you let us know how that goes? Thanks!
by
Add a comment
Add your answer
A name will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 95
