A new model arrived in 1998, launching the (EF) series. Engines were the 2.0-liter with 136 hp, 2.4-liter at 138 hp Hyundai Sirius and a 2.5-liter with 168 hp—the G6BW model of Hyundai Delta V6.
Battery keep running down
Why battery keep losing g charge
1 Comment:
@puresilk7287033how old is the battery? what have you checked? How do you know it keeps losing a charge? Have you checked your charging circuit to ensure that it is being charged properly?
Give us more details about all of this.
by
Add a comment
1 Answer
The most likely cause is a parasitic current draw; you need to disconnect the negative battery clamp and use a DVM set for milliamps. Plug the test leads into the jacks for current testing, connect the negative lead to the negative battery cable, and touch the positive lead to the battery post. The reading should not exceed about 50 milliamps.
An alternative quick test: Charge the battery and leave the negative cable disconnected overnight, connect the cable in the morning, and if it starts ok, test for parasitic draw.
The first thing I would check is the alternator, a shorted diode or some other problem in the alternator is fairly common. Disconnect the alternator and repeat the current draw test.
Add a comment
Add your answer
Puresilk7280@yahoo.com will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 21
All Time: 135
