Released in 2021, this lineup of the F15's features an Intel i5 or i7 processor, NVIDIA GeForce RTX GPU, and 15.6 inch 1080p display. These laptops have a sleek design and hardware optimized for performance-driven gaming at a lower price level.
darker portion on the display
At 144hz refresh rate when the brightness is reduced, there are some part on the screen which is unevenly darker than normal. The problem is restored when the brightness is increase or rr is set to 60hz.
Add a comment
1 Answer
This issue is usually related to the display panel or refresh rate handling. Uneven darker areas at 144Hz and low brightness often indicate panel uniformity issues or backlight/PWM behavior. Try updating your graphics drivers and adjusting settings like adaptive sync or color profiles. Test different refresh rates and brightness levels to confirm the pattern. If the issue disappears at 60Hz, it could be a panel limitation or hardware defect. Also check if any display calibration software is interfering. If the problem persists, the screen itself may be degrading, and panel replacement might be required for a permanent fix.
Add a comment
Add your answer
Jarren will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 121
