Blackview P10000 Pro as a phablet with a 6.0" display. Quad cameras, 16.0MP + 0.3MP dual back cameras and 13.0MP + 0.3MP dual front cameras. 4GB RAM & 64GB Flash storage equipped with Android 7.1 OS with a 11000mAh Battery
Why is my adapter overheat
My adapter overheat
Add a comment
Most Helpful Answer
@ghibral777 if you are referring to your power adapter, the there are at least two possibilities. One is that your Blackview P10000 Pro is pulling to many amps from the charger. You can verify that by connecting an ammeter between the charge and your Blackview. Replacing the battery can help with that.
Or it is your charger that is having internal components that are starting to fail and are overheating. Those chargers are really not easily fixed so you may need to replace it. Start with the phablet first. Of course, also make sure that the charging cable etc. is in good condition an not shorting out anywhere.
Score 1
Add a comment
Hello Ghibral,
When you say adapter, do you mean the charging brick? Is common for charging bricks to get warm while charging your device. If it starts to smell or melting the plastic, stop using it immediately and replace the charging brick.
Add a comment
Add your answer
GHIBRAL777 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 80
