repair air pump internal
the tympanometry internal air pump has a worn out internal rubber bladder. if the part can be identified and replaced rest of tymp works. would like to repair and donate as a screening device to a free clinic. would appreciate advice and or help
Add a comment
Hi @barryskobel
Unfortunately there's no part information re a pump bladder in the service manual - see p.88 only an o-ring - see p.88
Add a comment
If the tympanometer’s internal pump bladder is worn, it may be possible to replace it if the pump manufacturer or service manual identifies the bladder as a separate part. First confirm the tympanometer model and pump assembly, then check with the manufacturer or a medical-equipment repair supplier for the correct diaphragm/bladder. After repair, have the pressure and volume functions calibrated and verified before donating it for clinical screening.
Add a comment
Add your answer
Barry Skobel will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 32
All Time: 155
