My phone is ghost touching
After changing the screen the phone just operated normally or properly for a day and suddenly started to press keys itself.I tried to press the volume keys and power at once but couldn't work out.what could have caused this problem?
Add a comment
1 Answer
Most Helpful Answer
@willykaputa could be a bad replacement. I would ask the seller to refund you or, if you used a repairer to replace the screen, to do it once more. Anything else will be on the main circuit board. Could be the connector or could even be an issues with the circuitry. First step should be to replace the screen once more. If it happens again, you know that you will need to have somebody check your circuit board.
Score 1
Add a comment
Add your answer
Willy Kaputa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 97
