The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
Disc board fails to spin disc
I've got a gamecube with an interesting problem. I have another cube that is known working and I've done part by part swaps (motherboard, disc motor, hinge switch) to narrow down my issue. Something on my disc drive board is wrong and it will not spin the disc. Changing the motor to my known working cube proves the motor isn't the problem. I even swapped the good motor to see if that will work, which it didn't. I have a cheap multimeter and the caps are taking a charge and discharging as normal. A reflow of the hinge connector has not fixed my issue. I'm at my wits end and about to call it a lost cause.
Add a comment
1 Answer
Most Helpful Answer
Hi!
Pretty sure that the caps failed on the disc drive board…
I would replace them and see what happens.
You can find the kit here: https://console5.com/store/nintendo-game...
Please let us know how it goes!
Score 1
Add a comment
Add your answer
D2 the Hobbiest will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 104
