Why is my laptop screen blank?
I can see the start screen but i goes blank after some seconds?
If your laptop shows the startup screen and then goes blank after a few seconds, the issue may be related to display settings, graphics drivers, or hardware problems. First, restart the laptop and try entering Safe Mode to check if the display works normally. If it does, update or reinstall the graphics driver. You can also connect an external monitor to see if the system is still running while the laptop screen is blank. If the external monitor works, the laptop’s display cable or screen may be faulty. Additionally, check power settings and brightness levels, as incorrect configurations can sometimes cause the screen to appear black after startup.
yeah this happened to me too lol—start screen shows up then poof, blank. for me it was just the graphics driver being weird, booted in safe mode and updated it and worked fine. if it’s an older laptop, also check the screen cable, sometimes it’s just loose
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 85
