Holden commodore v6 ve
Engine running rough turns but whilst running. Had a new timing chain spark plugs and coils
Hi @junekiely
2006 VE Commodores have an OBDII port, so the quickest way to find out what the problem is to get the port scanned using a suitable scantool¹ (select your vehicle to find suitable scanners) to check if any DTC (diagnostic troubleshooting codes) have been stored by the Engine Control Module (ECM).
The DTC code will tell you what the problem is. You can then search online what the DTC code means and what to do to fix it
¹ supplier example only to find a suitable scanner. Then look for other suppliers that suit you best
Without codes there's not much we can do, but those V6s are similar to the ones in the US cars in many ways, even if they have been altered for RWD from FWD as a lot of those V6s are setup for in the US.
First thing I'd do without codes is change the spark plugs, especially if it has over 100k miles - iridium plugs can hit 120k miles in a lot of cases (and they don't degrade as quickly as traditional plugs) but 100k is the upper limit for iridium before you have issues. In Australia, 160,934 miles is when they hit the equivalent of 100k US miles. If that doesn't work, change the coils out - generally speaking when it comes to GM V6s, they're parts bin specials in the US (unlike the V8s here, especially Corvette and Cadillac V8s) so you can pretty much buy them for very little everywhere. It's probably setup for RWD with a drive shaft but it has the same coils as a V6 Impala and many, many others.
If these do not work, check for oil in the pistons - if you see excessive oil in the pistons by the plugs, the piston rings are bad and you'll need to rebuild the lower block. I know you guys have real consumer protection laws where you shouldn't have problems if the vehicle is relatively new so that may be an option as well.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 157
1 Comment
Please answer my question
by June Kiely
