Wi-Fi and Bluetooth are weak.
Hello, the Wi-Fi and Bluetooth have become weak, I think because I've dropped the phone repeatedly. I tried to get it fixed at a repair shop, but at first they said the problem was with the IC. However, when they went to replace it, they said the problem was with a smaller part and couldn't fix it.
Add a comment
1 Answer
ok so since they say that the ic isnt the pronlem. thats bad.... cuz many thing can be the issue .
  1. loose, degraded micro connectors or coaxal cable which mimics ic problem
  2. the regulator which gives power supply to the ic and if it is damaged the ic underperforms causing your issue.
  3. PA or power amplifier boosts range problem with that can result in the issue.
  4. problem in filters that filter other noise can be an issue if it is blocked
ya thats all i can provide you with i do recommend going to a specalist and check ing the following problems if the ic isnt an issue. basically if the ic isnt an issue the suppporting parts of the ic are and its a pain to fix man. its best if you change the problematic component.
Add a comment
Add your answer
Mark will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 13
All Time: 64
