The HP EliteBook 800 series includes display sizes that range from 12.5 to 16 inches, supporting refresh rates up to 120 Hz. Processor options include the Intel Core i5/i7, 13th/14th Gen or the AMD Ryzen 5/7 7000 Series. Certain configurations also may support up to 64 GB of memory and up to a 2 TB SSD.
Black screen when switched on
Black screen when boot
Add a comment
1 Answer
If your HP EliteBook 800 shows a black screen when powered on, it is usually caused by display, RAM, or BIOS issues.
First, try a hard reset. Turn off the laptop, disconnect the charger, remove the battery (if removable), hold the power button for 15–20 seconds, then reconnect power and turn it on. This can clear temporary hardware glitches.
Next, connect the laptop to an external monitor using HDMI or DisplayPort. If the external display works, the issue may be a faulty laptop screen or loose display cable.
You can also try reseating the RAM or booting with one RAM stick if the laptop has two. Faulty memory often causes a black screen at startup.
If none of these steps work, the problem may be related to the motherboard or BIOS.
Add a comment
Add your answer
Sylvester Owusu will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 32
All Time: 159
