Oil mixing with water
Why is oil mixing with water in the radiator water reservoir tank?
@augustineaduge the most common issues for that are:
you did not tell us what you have already checked or if anything happened to your MB just prior to this. At minimum I would suggest a compression test as well as a Cylinder Leak-Down Test which will be the most diagnostic test.
For any further help, we will need to know the exact engine size/model of your Mercedes Benz
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 73
