13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Removing Mold from the internal display frame
I live in quite a humid country and I encountered so many time a moldy inner frame from the A1278 models display. This part alone is not available as a separate piece or even worth to buy considering the overall value of these old MacBooks, anyway, damp is obviously a cause of mold, so cleaning one of these up to recycle is a bit of a challenge long term. What method would you recommend to use to get off the mold? I have been scratching off as much as I can and then sanding it down and then using some 99% ISP to finish it off before spray painting them black to give them some sort of 'protective' coating afterwards. @danj have you ever had to do this before? Interested in any suggestions. Thanks in advance!
Add a comment
1 Answer
Chosen Solution
A mild solution of bleach is about all I can think of using distilled water. Some bathroom tub cleaners offer stronger chemicals which will attack the heavier stains, wear proper PPE as they can splash burning you.
Score 1
1 Comment:
Bleach haha I forgot all about using that, I clean the bathroom every other day with some nice lemon fresh :)
by
Add a comment
Add your answer
livfe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 124
