Why the air compressor not starting?
Why air compressor not starting
@innocentmutepfa start by checking fuse #28E which controls the compressor clutch relay. If your fuse is good, you will need to check the relay. Here is the Land Rover Discovery 4 HVAC Wiring diagram. Use that to check your compressors power lines.
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 40
All Time: 178
1 Comment
@innocentmutepfa have you checked your fuses? What have you checked and tried already?
by oldturkey03
