The Toyota Vitz is a subcompact hatchback originally launched in 1999 as a successor to the Toyota Starlet. It is being internationally sold as the Toyota Yaris or Echo. There are currently 4 generations of the Toyota Vitz.
Why the engine is vibrating too much?
The car's engine is vibrating too much leading to the car being not comfortable to drive
Score 3
3 Comments:
When start my car the engine vibrate too much until the car is warmer
by
@guleidahmed here is not enough information to provide you with an answer. you will need to check your fuel pressure as well as your vacuum lines. A vacuum leak can cause this. Have your OBDII scanned for an exact diagnosis.
by
another reason could be engine mounts
by
Add a comment
1 Answer
sounds like most likely you have a misfire. have it connected to a OBD ll and see what codes it throws.
Add a comment
Add your answer
Themba Phiri will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 82
All Time: 746
