Up to 20% off select tools
Keyboard light is working
When I gave my laptop to ashop to put ssd after that my keyboard light is working
Add a comment
Most Helpful Answer
Hi @saviodominic
Do you want the keyboard backlighting to be on or off?
See the image below for how to turn the keyboard backlighting on or off using the designated Action key on the keyboard.
(click on image)
Score 1
4 Comments:
Hello my keyboard back light is not working but days ago is on and goes off but now it not turn on when i press the light button
by Share
@saviodominic
Check in BIOS for a keyboard backlight enable/disable setting and make sure that it is enabled.
Also check that the keyboard drivers in Device manager are up to date.
Has the laptop been dropped or the keyboard gotten wet since it was working and then stopped working?
by Share
what are the step in checking for bios
by Share
@saviodominic
Here's a video that shows how to enter BIOS.
Once you're in you need to look for the keyboard backlight setting. Maybe in the "Advanced " or "Configuration" menu, not sure
by Share
Add a comment
Well check your BIOS/UEFI settings to ensure the backlight is enabled.
Add a comment
Add your answer
Savio Dominic will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 194
