ASUS TUF Gaming Laptop - FX505D-DBQ234T with i5-8750H and Nvidia gforce GTX. MFD-2019-05.
Why does my computer keep resetting when I start it up?
My computer keeps resetting itself repeatedly when I start it up.
1 Comment:
@dongtran what resets? Any possibility this is a BIOS issue?
by
Add a comment
1 Answer
If your computer keeps restarting during startup, it’s usually caused by a hardware fault, corrupted system files, or a failed update.
First, try booting into Windows Safe Mode to see if the system loads without restarting. If it works there, a driver or recent update may be the problem. You can also run Windows Startup Repair from recovery options to fix boot errors.
Other common causes include faulty RAM, overheating, or a failing power supply. Checking hardware components and running the Windows Memory Diagnostic tool can help identify the issue. If the problem continues, reinstalling the operating system may be necessary.
Add a comment
Add your answer
Dong Tran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 61
