Up to 20% off select tools
The a7R II (model no. ILCE‑7RM2) is Sony's 2015 revision to their full-frame, mirrorless, interchangeable-lens camera.
Shutter keeps getting stuck randomly
My camera keeps saying shutter issue randomly and tells me to turn the camera off and on again, sometimes this doesnt even work and I have to remover the battery then it works again until the issue happens all over. Any suggestions?
Add a comment
1 Answer
There is a mechanical shutter in this camera that can get gummed up. Time to take it to a Sony authorized service center so the shutter can be replaced.
2 Comments:
Its not the shutter, its something to do with the Steadyshot I believe
by Share
@isaiahpimentel - Steadyshot is located within the lens which alters the lens position to offset the small movements within the image. Unless you are getting an error it won't stop the camera from capturing an image.
Try using a tripod so the camera is unable to move does the camera still fail to take a picture?
by Share
Add a comment
Add your answer
Isaiah Pimentel will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 48
All Time: 415
