Up to 20% off select tools
Repair and disassembly information for Google's Pixel 8 Pro smartphone, released in October 2023. Identified by model numbers G1MNW (NA/AU), GC3VE (EU, India), and GE9DP (JP).
Battery Replacement Calibration Issues
I got the new battery installed and drained it all the way down
Does go to 100% but I have to restart it to get the percent to change and when it does it says around 71% or 80% until it dies.
Add a comment
1 Answer
Hi Anthony,
Where did you purchase the battery from? If it wasn't an OEM part or made by a reputible manufacturer, it may be lacking some of the necessary sensors for determining percentages properly.
However, there is a quick fix that may work that you can try:
  1. Charge your battery for a long period (overnight) so that it fully charges and then some. Ideally, do this when the phone is turned off.
  2. Turn the phone on and use your device until the battery is completely drained and shuts off on its own (I would reccommend turning the screen off time to never and running a very long video with sound to speed this process up)
  3. Plug your phone back into the charger and charge your battery to 100%. It is very important not to interuppt the charging process, so I'd probably leave the phone unattende overnight.
If this does not calibrate the battery properly, unfrotunately, the best option is probably to purchase a new battery. You can get an OEM battery from Google on the iFixit shop website: Google Pixel 8 Pro Battery - Genuine
Replace a dead or damaged model GUKD8 battery for a Google Pixel 8 Pro smartphone. Image
Product
$52.99
4 Comments:
Bought from ifixit
I will try that again
Thanks
by Share
Ok, great. If you purchased this from iFixit, I would suggest that you contact their customer service. If the battery does not work, they should probably give you a replacement/refund
by Share
Drained it until it turned off
Put it on the charger for I want to say 12 hours
charged to 45%
plugged it back in after that and charged to 100%
that was this morrning, had it off the charger from 8am to 2pm it is telling me it is at 98% right now. It is acting like it does not want to update the percent.
by Share
Add a comment
Add your answer
Anthony P will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 40
All Time: 390
