The Samsung Galaxy A14 5G is an android smartphone developed by Samsung Electronics. It was released in January 2023.
How can I fix emergency call only
My phone simcard network not working in this phone but when i get insert to another phone are working
Score 1
1 Comment
Did you buy your phone from a network provider such as (Telstra/BigPond, Optus, Vodafone)? Your phone may have a "SIM Lock" on it which is a lock that only allows you to use that providers SIM with the phone (say you bought it from Optus, you'd only be able to use an Optus SIM)
If so, you should be able to ring them up and ask for the unlocking code.
by
Add a comment
Chosen Solution
Hi Elijah,
Make sure that the SIM card is compatible with the Samsung Galaxy A14. For this phone, you will need a Nano-SIM card (4FF) that supports either 4G or 5G. It's great that you have already tested the SIM card in another phone, so we know that the card itself is working.
Does the new Samsung A14 have WIFI connectivity? Also, have you ever used another SIM card in this device before? These questions will help me narrow down what the issue might be.
Let me know if you have any questions!!
Score 2
5 Comments:
Yes wifi is connecting and i was using another simcard before
by
Ok, that is good to know! Since WIFI can connect, can you check to see if there are any updates for the phone? Also, make sure that celluar data is enabled.
If neither of those steps work, try taking the SIM card in and out of the phone and wiping it off with a dry cloth to make sure the connectors are clean.
Let me know how that goes!
by
I have a Galaxy A14F. Recently it stopped connecting to network and my sim cards don't connect either. The sim cards work perfectly in other phones so I know it's not a provider issue.
by
Ok great. That narrows this down to an issue with the phone itself. We don't know if it is a hardware issue or a software issue though.
To test this, first turn on Airplane Mode and leave it on for 1 minute. Then turn airplane mode off. If this does not work, you can also try going to Settings > General management > Reset > Reset mobile network settings. If neither of those steps work, then there is likely a hardware issue with the antenna board or the motherboard.
by
If it is a hardware issue, your best bet is probably taking the phone to a repair shop unless you have the tools for disassembling the phone yourself
by
Add a comment
Is phone mein light apne aap kam ho jaati hai apne aap Jyada Ho Jaati Hai Isko Kaise Sahi Karen
1 Comment:
Samsung Galaxy a5g Mein supply Nahin a rahi hai
by
Add a comment
Add your answer
Elijah Mwachoka will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 442
