Up to 20% off select tools
Repair guides, disassembly, and troubleshooting information for the iPhone Air, announced September 9th, 2025.
Back glass replacement idea
Does it requires the transfer of the wireless charging coil and flash from the previous to the new ?
Add a comment
Most Helpful Answer
Yes, in most cases you’ll need to transfer the wireless charging coil and the flash assembly. They’re attached to the back housing and usually aren’t included with replacement glass unless you’re buying a fully pre-assembled rear housing.
You can see how it’s handled in the iFixit guide here:
iPhone Air Back Glass Replacement
That guide shows what’s part of the back assembly and what needs to be moved over.
Score 3
Add a comment
Depends on where you buy the part and what quality of part you get
Add a comment
Add your answer
Divine Egba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 60
All Time: 347
