How do I fix my mouse pad
So I was using the laptop normally until the mouse pad stopped working so how do I fix it?
Hi, @ahmedayman93805 I gotchu.
I found the replacement mousepad here. Ask FixBot to assist you with replacement.
Well Check the "Magic" Function Key and also check for driver sometime outdated driver can also be the reason of this issue.
If your laptop touchpad suddenly stopped working, start with simple checks. Make sure it isn’t accidentally disabled—many laptops have a function key (Fn + F-key) to toggle the touchpad. Restart your system, as it may be a temporary glitch. Go to Device Manager and check if the touchpad driver is missing or needs updating; reinstall it if necessary. Also check Settings > Touchpad to ensure it’s enabled. Disconnect any external mouse, as some systems disable the touchpad automatically. If none of this works, it could be a loose internal cable or hardware failure, requiring professional repair.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 31
All Time: 186
