No sound in the speakers
The amp is not producing sound
Add a comment
1 Answer
We'll need more info. Make and model of amp will help. To start, double-check all the connections such as 12V positive and ground, remote turn-on, RCA inputs or speaker-level inputs, and speaker output wiring. Use a test light or multimeter to make sure you're getting 12V to the power input and remote turn-on input. It can be helpful to have a known working amp to substitute and test things out that way. Run new temporary speaker wires to the speakers so you can rule out bad wiring.
Add a comment
Add your answer
Kevin Nyongesa will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 105
