Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
How to remove a stripped Y000 screw?
See image content:
Add a comment
Most Helpful Answer
This is a common enough problem that iFixit has put together a guide giving you some best practice ideas on how to get a stripped screw out. Take a look and let us know if anything helps.
How to Remove a Stripped Screw - iFixit Repair Guide
Score 2
Add a comment
Use some WD-40 or screw remover, then use a slightly larger screwdriver head and use a hammer to bang it in there. Then continue to unscrew as normal. If that doesn't work, try (carefully!) using a power drill with to drill a hole into the screw, then use the same slightly larger screw head to unscrew. Hope it works!
1 Comment:
Yeah, these screws are microscopic; your standard screw removal techniques like what you'd use on a car aren't going to be much help here.
by
Add a comment
Add your answer
Platinum135 Phantom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 123
