Why does my speaker sound like a fart?
When I pulled the hair out of the speaker, I tried to turn up the volume and it sounded like a fart.
It means the speaker is distorting or the speaker cone is damaged.
Since you pulled hair out of it, a few things may have happened:
Possible Causes
Speaker cone torn or punctured – Even a tiny tear can cause a buzzing/farty sound, especially at higher volume.
Debris still inside – Hair or dust trapped under the speaker grill can vibrate.
Loose speaker membrane – Pulling hair might have slightly pulled or dented the cone.
Overdriving the speaker – If you turned the volume up suddenly, it may be clipping.
Water or moisture – If anything damp touched it, distortion can happen.
What You Can Try
Lower the volume to 50% and test.
Play different audio (music vs. system sounds).
Gently blow compressed air into the grill.
Update/reinstall audio drivers.
Check with headphones — if headphones sound fine, it's definitely the internal speaker.
If distortion happens even at low volume, the speaker is likely physically damaged and may need replacement (usually inexpensive to fix).
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 50
All Time: 275
