Repair and disassembly guides for electronic keyboards.
Casio WK3700 DSP not working
I have an old Casio WK3700 electronic piano/keyboard.
When powered on in Grand Piano mode 000 it works fine. If I try any other mode the DSP button lights up and it emits a distorted thrumming sound and eventually powers off.
I assume the DSP circuitry is stuffed. Video
Score 1
Add a comment
Most Helpful Answer
Hi @wayne51244
If you haven't already done so try to reset the keyboard back to default and check if that fixes it.
  • Remove the batteries from the keyboard (if inserted) and disconnect the AC adapter from the keyboard
  • Press and hold the Power button operated for about 20 seconds and then release it.
  • Reinsert the batteries (or reconnect the AC adapter), and turn on the keyboard
  • Use the Transpose/Function button to perform a system reset.
Score 1
1 Comment:
Thanks for this. I'm gunna look pretty silly if it works.
by
Add a comment
I have same issue and hoping to replace the IC4
Add a comment
Add your answer
wayne will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 123
