A desktop, more conventional model of the Square POS device. Has two touchscreens, one for the cashier and one for the customer.
It does not seems to be working
I was asking if someone knows anything about this how to open them because mine does not works but screen looks like they work so i was thinking of doing an DIY project to use this screen as my external monitor if possible
Add a comment
1 Answer
Chosen Solution
Do you know if it is Windows or Android based? If it's Windows based, it's probably something like W11 IoT Enterprise GA or even a fixed year like 202X. If that is the case, it is likely based on iDP or HDMI internally. If it is based on HDMI with a embedded PC inside, you can probably run it straight to a PC with an HDMI extender. Failing that, get the part number from the LCD and look for a driver board like people use to convert broken laptops and AIOs to monitors. Some are also known to use MIPS, no matter the OS base.
If it's Android based, then it is based on a protocol like LVDS or iDP and you will need a driver board that takes the signal and makes it "PC friendly". Again, LCD will tell you what you need. I would not expect it to be possible to convert the "customer display" - let that one go. It's thoroughly nonstandard as it's meant to be part of the terminal.
EITHER WAY YOU WILL KILL IT'S USABILITY AS A TERMINAL. Once you mess with the hardware it will kill the encryption keys used to handle transactions! I would also not use it in a business, like... at all, even in the back. Take it home and use it as a ancillary display.
This is what you will need to convert to -- DP or HDMI, I would avoid VGA:
Score 1
2 Comments:
Yes, Thanks for the reply. So yes it is like an andriod base not window i dont need it for terminal use any more but want somthing to do different for in home project I dont mind if i gets ruined I just wanted to try somthing unquine and different. But I didnt understand the process you explained to me can make it easier for me
by
@talalsyed Take the LCD number and then see what it uses - LVDS, DP (iDP) or MIPS. The big terminal will probably be LVDS or iDP, customer display is usually MIPS.
Once you know, take the model and look for a driver board which will provide DP, HDMI and VGA.
by
Add a comment
Add your answer
Talal Syed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 138
