Apple's mainstream 2021 iPhone was released on September 24th and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 12.
iPhone 13 proximity sensor cable damaged
I have damaged front proximity cable: do I need whole assembly or just the cable? Ifixit sell front sensor cable but currently out of stock?
Add a comment
1 Answer
Most Helpful Answer
By the "whole assembly", are you talking about a screen with the front sensor already attached? If that's the case, then no, you definitely don't need that; the front sensor assembly alone will allow you to replace the proximity sensor.
iPhone 13 Front Sensor Cable
What country are you in? Availability varies by country; here in the US they're still in stock. Keep in mind that Apple doesn't sell their parts to anyone other than certified Apple repair shops, so all of iFixit's parts are aftermarket. Granted, they do go out of their way to find quality parts, but if they don't have them in stock it doesn't help you. You can click on the notify me button and get an email when the parts are back in stock, or check out some of the larger parts sellers; there are plenty of reputable dealers out there.
Be aware that you will lose Face ID when you replace the proximity sensor, as it's paired to the logic board. If you use Apple's Self Repair program, they will allow you to run their configuration tool to pair the new part (that you have to buy from them) to your phone, thus restoring Face ID. It's unclear if the Repair Assistant, available as of iOS 18, will let you pair a genuine Apple part (new or used) and restore Face ID.
Damaged flex cables can be repaired or replaced, but it requires some very specialized skills to do so, as shown in this video.
iPhone Proximity Sensor Assembly Repair (Two Methods) (Tips and Tricks #22) - YouTube
Replace the front sensor cable for an iPhone 13 model A2482, A2631, A2633, A2634, or A2635. Fix problems with sensor functions. Image
Product
$23.99
Score 1
Add a comment
Add your answer
Andrew Dent will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 51
All Time: 254
