Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
Power outage alarm keeps beeping
Power outage alarm keeps beeping? Replaced circuit board and door sensor? Help
Update (02/04/26)
Frigidaire gallery FG4H2272UF
1 Comment
Hi @eileen76881
What is the make and model number of the refrigerator?
by
Add a comment
1 Answer
Most Helpful Answer
Hi @eileen76881
Since the alarm doesn't stop after any key is pressed (power outage alarm should reset by pressing any key on the panel, once power has been restored and refrigerator set temps are OK) and you've replaced the mainboard and door sensor, perhaps some other component has failed indicating to the control board that all is not right.
Here's the service data sheet for the refrigerator.
Enter the System Diagnostic Mode, as described by the sheet and then run tests on all of the sensor and switch tests that can be done to make sure that they're all OK.
There is a note in the sheet which states "Contact TID before replacing main control board.". I assume this means their Technical department.
Perhaps there's some setting or jumper that needs to be set on the board for it to suit you particular model as the board may be used in a few other models as well. I don't know. I had to do this on my Fisher&Paykel fridge as it didn't work properly after replacing the mainboard (replacement board was the correct board) until I configured the board using info provided by F&P tech support for it to suit my exact model
Score 1
Add a comment
Add your answer
Eileen will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 51
All Time: 235
