The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Cause of shutdown when sleeping
What would cause this unit to shutdown after around 20 minutes when put to sleep? We haven't changed any battery or sleep mode settings and the battery is a good one. We can close the lid and open it after a few minutes and all is well, but when it is left closed for say 20 minutes the unit is turned off. We tested it with our clean installed SSD and the same happens..... We have reset the SMC, PRAM, run diagnostics & there are no errors being reported, ..... I have been told this was an issue with Monterey & up, but I never encountered this before....I noticed that when it is connected to a charger it didn't shut down after the lid is closed for a longer time. System is on 12.7.6.....baffled.
Score 1
2 Comments:
Is there any indication if it shuts down, or just powers off?
What if the lid remains open, and you put it in sleep mode manually?
by
@allanbinderup Only when the lid was closed for around 20. minutes, I tried sleeping it manually and it operated normally.....
by
Add a comment
Hi, @livfe I gotchu.
Tip
Replace the whole logic board and tell us what happens.
1 Comment:
Errrr.... Maybe, but the idea here is to fix this unit board included....
by
Add a comment
Give this a read Understanding sleep modes on MacBook Air
Add a comment
Add your answer
livfe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 185
